yamaholic22 said:if you dont believe it do an apples to apples comparison in the same conditions running to the two different tracks. Its not the weight that is the issue with the taller lugs, it's the fan effect created by the lugs, they make A LOT of wind resistance, and the air gets trapped up in the front of the tunnel around the axle and actually mildly compresses, adding to the problem. Apples to apples, taller lug tracks DO drop top end, its not a question.
