jet needle slightly bent?
you're kidding right? If its bent (however that happened) locate the issue that caused it to bend and fix it, and definately get a new needle. Having a bent one could definately change the calibration.
It's bent about 1/16" if that. I may have bent it pulling it out but not sure. I reinstalled it anyway and slides work fine, no binding that I can tell and it sits in the same spot as the rest of them(triple)
even if they are worn slightly (not even visable) they can make the sled run like crap. You are risking a lot to save a little
