TimmySRX
I have a set of Front ohlins that I need to replace the rod in anyone know where to find replacement parts and or a good place to have them serviced. contact info and or web site.
Thanks,
Thanks,
If you can rebuild it yourself, you can order the parts directly from Ohlins. I bought the shaft and it was only about $75. Pioneer Performance can also rebuild the shock for you, and they make their own shafts also, which are slightly more expensive than ordering from Ohlins directly.
TimmySRX
Hey jwifferdill
Thanks for the info, I think form older post you were working with rebuilding your own shocks, can you point to a link to a web site or some sort of contact info that would really help me out. Again thanks.
Timmy,
Here are a couple links:
http://www.totallyamaha.com/forums/showthread.php?t=9477
http://www.totallyamaha.com/forums/showthread.php?t=9180
http://www.totallyamaha.com/forums/showthread.php?t=8761
I have the rebuild specs also if you plan on doing it yourself. My brother rebuilt mine and said it was kind of a big job, but it can be done. Hope this helps!
