Great brake won't work
x2ryder
Moline, Illinois
Just changed my track and now the brake won't work???? Bled it and still won't work. Also how do yo get the insert in the drive shaft out to replace for the speedo key?
if you expanded the pads you'll have to pump it up before it will grab, takes alot of pumping sometimes. after that the only other thing it can really be is the keyway that gunner mentioned.
