x2ryder
I need 3 8bu10's clutch weights
nailsandrails
What are you going to run them in? Just curious because a couple of years back I had a ported 98 SRX from Hauck that ran those weights. I never see anyone on here using them. I was running them with his roller.
x2ryder
I am gonna run them in a 2002 srx 780 big bore. Gary from maxx perf reccomended me using them. By chance how much weight did you run in them? Thanks
John W
- Oct 20, 2004
I have a new set in my shop if you are still looking fo them. let me knoe email
John W
- Oct 20, 2004
Ahhh that would be "know". Dam fingers are too fat!
nailsandrails
He used a nut and bolt in the end. If I remember right I put them on a gram scale and the nut and bolt was 4.5g. I know I have it in some old notes somewhere!! Keep in mind this was running with his roller secondary and a straight 45 degree helix. I can't remember the spring, but it was wrapped at 90 degrees. I also can't remember the primary spring. This was a fun trail set-up. I went to the heelclickers down the road and felt that they performed as good on the low end and a lot better through mid-range on out. I went away from the roller at that point becuase I couldn't get the clickers dialed in with it. It backshifted better with the roller and original set-up, but the clickers were faster.
YAMMIEGOD3:16
THOSE ARE STOCK WEIGHTS THAT CAME IN THE 97 VMAX 4 800 !! THEY ARE LIGHTER THAN THE 8BU-00 WEIGHTS WHICH CAME IN 95-96 VMAX 4 800 !! 3:16 (tony)
x2ryder
I still need 3 of them anyone?????
Junior
I might have a set in my race box, I'll check it this weekend for you
viper paul
- Jan 18, 2005
i have one even better hauck adjustable x weights ,awsome weight easy as pie to dial in 70.00 shipped p.m. me if interested or call my cell 847 651 8494
