98 SRX problems when I turn left
balael
I just bought this 98 srx, has been in one accident which did the following things to the sled....
bent the left side trailing arm
bent the lower left radius rod
bent up the belly pan a little bit
which hit the clutch and either blew the clutch apart, or just the belt
which blew through the clutch cover
and spider cracked the hood
Driving it is fine, turning right is fine, but whenever I turn the machine left there appears to be a noise coming from the drivetrain area. Was wondering if anyone has had a similiar problem, or any advice before i tear down the sled. Thanks.
pj
