it is directly under the engine on the mag side (right side if you are sitting on the sled) under the rear motor mount. There is enough room that you should be able to fish out the wiring harness if you unplug all the wires from the hood. Once you get them out, if they aren't rubbed through yet (like if the sled is brand new), you can just put some electrical tape and then wire loom on the length of wire under the engine. A lot of people run the wire loom all the way up to the hood for the looks, your preference. This will prevent the wires from rubbing through and grounding out on the motor mount, engine, and frame.
