We have a MM600 that I have thought about doing the same thing to. What I have found out is the motor is easy, just cylinders, pistons, and head, you will need the 700 carbs. The electrical is the hard part, I have heard you just need the CDI box. But if you look at the parts differences between a 600 and 700, you will see that almost everthing is different, stator, coils, rectifier, etc., etc.
