2mas
- Apr 4, 2005
i have a 2001 stock srx 700 non studds i will drag race with on snow(660ft)
how will you srx tuners settup the clutch for best performance??
hope someone have som good settup
2mas
2mas
kawirider00
put studs in or have it rev around 8400 and weight if it over revs take it out if it under revs
yamaholic22
you are going to want a taller lug profile if you are racing on snow, and definately a set of transfer rods.
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
Ya unless you're racing on hardpack you will want a big lug track. Transfer rods would be good too as yamaholic said
Top RPM should be 8400-8500. I have my engagement at 4500 RPMS. My setup is for all types of riding though not just racing, so maybe you'll want yours even higher????
yamaholic22
actually for snow drags you will want to get the engagement down lower than you would for ice or grass, so that it doesn't have the tendency to break the track loose on engagement.
2mas
- Apr 4, 2005
whats gearing,primary spring,weights , helix ????
yamaholic22
for gears i would say you would want to be around 22/39 or so, and i would've said 8BU weights but i doubt you will be able to keep traction with them. If you had some killer traction it would be a lot easier to give you a good set up. Anyone else? I wouldn't go too steep on the helix for the same reason, you want it to apply the power smoothly, not slam it down quick, because it will just want to break the track loose.
BlueByYou2000
Super Moderator
Gearing, 38/19
Clutching
Heavy Hitters with appx 54 grams total
Maxx Perf Purple primary spring
Straight 47 helix
Yamaha green secondary spring, set at 90 degrees (6 and 3)
Clutching
Straight 47 helix
