TJ500
Does anyone have any input for replacement carbides on my MM700.... Presently with the stock carbides, it steers just as my VW beetle did in the 70's when there was lots of snow...(that is no steering what so ever)...
Track is stock 2" without studs....Skis ar stock plastic....Just want to rail corners the best I can without plowing into the side.... This thing doesn't handle anything like my 500 but I would like some improvement....
Is 8 inches of 60 degrees on 1/2" bar with wear pads too much?....
Thanks...
Thanks...
Give this guy a call. He has some of the best skegs available and will give you no BS expert advice.
www.bergstromskegs.com
