I have a 97 sx700. Gas is pouring into one of the cylinders, it will actually fill up the exaust pipe. I cleaned the carbs and checked the floats every thing looks OK. Could it be the fuel pump? because when I do unhook the carbs from the fuel pump gas pours through the pumps gas lines, It never done that before untill now
its possable it the fuel pump but the inlet needle should stop that unless the sled is sitting on a angle....the inlet needle might not be seating...
