Yammerhead
Friends sled that I was tinkering with. The primary is engaging at idle and it looked to me that the belt was too short. It was an Ultimax 2 with the same part # that my 97 700SX would run. I looked on line and according to Royal Distributing that is the correct belt. The center to center distance on the exciter is quite a bit more than my sled, but that may be because of the different clutches.
Does anyone have the proper center to center and offset for this sled? Also, stock jetting would be good to know. I believe it has 320's in it right now.
Any info would be appreciated.
fishbone
I ride a '93 exciter II sx, and the info I have found for mine is 268.5 mm center to center, 15mm offset. Offset on clutches are 13mm.
