Whats a good choice? I'm going with at least a 2 inch riser and have a boss seat that has a 3.5 rise. I'm thinking of going with pro-tapers, but I"m afraid they will be too wide? any suggestions?
yamaholic22
i loved the set of pro tapers i used to have, very comfortable yet aggressive bend for me, and much stronger and lighter than stock. I would definately use them again.
I have a set of 2002 MXZ440 Race bars on mine, with hooks, power madd pivot block and 4 inch riser. best set up i have ever seen.
pro-tapers
Are the pro-tapers you used the motocross model? thanks
yamaholic22 said:i loved the set of pro tapers i used to have, very comfortable yet aggressive bend for me, and much stronger and lighter than stock. I would definately use them again.
mountainman
i used custom arct cat bars plus an 8'' riser and im 5'11'' and its SWEEEEEeettt
mountainman
im sponsored by powermadd i mite be able to hook u up!
yamaholic22
yes they were motocross style pro tapers
reply
do you know if the pro-tapers are 7/8" or the 1 1/8"?
thanks again!
yamaholic22 said:yes they were motocross style pro tapers
thanks again!
aSRX600guy
I ran wide handlebars for a while, I've got wide shoulders, it flt much better.
there were several downfalls.
the aftermarket bars were much stronger with a center brace, I believe this lead to a broken steering collum.
the extra width had my hands unprotected by the windscreen.
Made getting the cover on tough
the cables were at the limit, made TORS a problem. (going to be a real problem with a 2" rise)
