Studs Studs Studs
Cuzino19
Fort. Ontario
How many studs would it be if i had a 2,2,2,2 etc. pattern in a 136 inch track. What size of studs would I need for a 1.25 inch ripsaw track. Which studs would be recmmended. I do a lot of trail riding if that helps.
108 studs, either 1.25 or 1.325 inch stud height (yes the 1.25 WILL protrude over the lugs) Depends on the conditions you ride in and what you want the sled to do
i just want to get more bite, better for the trails around corners because i have 9" carbides in the front.
