srx600
when I first go for a ride with my srx and tried to put the throttle more than half for the 1st tell miles the clutch or something seems to hook up, make a noise and give a jolt. Does any one have any ideas on this?
TopGunnSrx
Do you have proper chain tension on it?Check that out
bad belt???
srx600
I changed the belt with no success when it was doing that.
does it make any sounds, in any specific areas???
srx600
it sounds like it is comming from the clutch side, it sounds almost like when a chunk of ice flies up into your tunnel and hits against it, that sort of crunch kinda sound, after that it gives a jerk and then I got another 10 miles before trying that again and it works fine. ????????????????
you check your lower jack shaft bearing???
srx600
didn't check that
any luck on your findings???
srx600
problem
did have much time lately, but I'll let you know when I check it out
blueblooded
problem with srx
i would guess that it is ice coming loose from under your tunnel,makes the noise when it gets to your drive axle.I have that happen all the time,the snow melts off the heat exchangers and turns to ice and when you first start out it comes loose and gets wedged between the drive axle and front heat exchanger.
srx600
problem
I never thought about that, but I have another srx and it doesn't do that so I dunno, I'll check everything out and see what it is.
