Millinocket Rocket
hammertime setups: Turk?
just about to put a set of hammertimes in my '02 viper, and wanted to see if anyone had any good setups/comments before i went with supertorquers base setup. i heard their setups were useless, so i figured i'd throw it out there. i'm running a heel-x roller w/42-38 helix, stock secondary spring, 1" 9830 camo track w/96 studs, ohlins shocks, torque limiter, and rev.-- everything else stock. do mostly trail and weigh 160- if that helps ya. appreciate any input
yamaholic22
are they the new style hammertimes, cut from a full piece of stock, or are they the first generation? There were quite a few problems with the first generation ones "holding together"
Millinocket Rocket
i know- i've heard horror stories about the older ones, but yes- they're the newest ones, with the billet aluminum hammers.
B2SO
- Aug 18, 2003
run the white spring , leave the tip and the and bottom holes empty , to start i would but the max weight in the swing shoulder i think that is like 3.5 grams , take it out and see what rpms you run , if you to high of rpms with that set up add a gram or two to the tip , you want as little weight in the tip as you can to pull the correct rpms ...
Millinocket Rocket
b2so- thanks for the info. i didn't get a white spring with it- all i have is a gray and a red. i've heard to use the red- better for trail use? i think i'm gonna try just what you said and just weight the shoulder to start. does more weight in shoulder= lower engagement? looking for low- 4000- 4300. now the summer's really gonna be loooong.(hmmm, wonder how it's gonna run with the new mods) wish i had some snow to try it on!
Millinocket Rocket
any others??
go to the other site and do a search under kirkswim. he and turk jut did his this winter and the setup rocks. or just pm turk directly. im shure he can line you up
Millinocket Rocket
maim, great- thanks for the help
np happy to help
