HELP SYPTOMS OF A JACKSHAFT BEARING GOING TO HECK,WORN GEARS
REDMATER
tya
ny
Website
mysite.verizon.net
WHEN I RIDE AT VERY LOW SPEED LIKE JUST BARELY MOVING I HEAR CLUNKING NOISE BUT IT SOUNDS LIKE THE TRACK SLAPPING ON THE SKID BUT. WHEN I CHANGED THE GEAR LUBE PRE SEASON THE WAS ALOT OF FILLINGS ON THE MAGNET. IM NOT SURE WHAT TO LOOK FOR,OR COULD IT BE A FRONT AXLE BEARING? ANY IDEAS GUYS
clunk -
It could be several different things, but if you havent changed your J shaft bearing you should anyway. You can also check your drive shaft (the one the cogs are on) I have bent one of those, and it had some odd sounds. While your down there--check to be sure your drive cogs dont look like they have spun on the shaft(or are about to). This is not your clunk, but I spun mine last year, and limped her home.(SX's only have 2 drive cogs)
This one is hard to diagnose at the computer.
Good Luck
