Brad
- May 23, 2003
having problems with hand and thumb warmers on my 2001 srx
the left hand warmer works a bit but not hot, the right one bearly works luke warn and the thumb doesn't work at all. Just had first ride of season and thats how they were. Help on this matter would be greartly appreciated.
Kgmz
You need to check the warmers for continuity, resistance with a Ohm meter. And check to see if you are getting voltage to the warmers.
I am not sure but does your sled have 2 different warmer dials, one for the grips and the other for the thumb warmer. If you are having problems with both the grip and thumb warmer, it is probably a voltage problem. So check and see what kind of voltage you are getting out of the warmer dials from full hot down to warm.
