ski question
02srx
pa
will 05 rx warrior skis work on a 02 srx any advantage or disadvantage thanks
they will fit because it's the same ski as the viper/venom, but the sled will sit aprox. 3/4 to 1" lower because the saddle area on viper-rx1 ski's have a lower spindle mounting point.the only difference is that the spindle lenth . you may have to take out some center shock spring pressure to reduce front push.
yup he's right it will sit about an inch lower. Can take your upper shock mounts off, do a little grinding, flip them and swap sides to get that inch back though.
