Lightning pro roller secondary
maxdlx
VIP Lifetime Member
Tipton, Iowa
Anyone running or have run one of these. What did you think, and what set up did you use. I am going to run it in a 02 viper. I have the stock 47 helix, a 53/43, and a 46/42. Stock spring, green spring, and an all silver one. Thanks Maxdlx
stock or improved???
the 46/42 is a real nice cam ......53/43 will be too steep...regardless...
also..if the cams are overdrive cut...you will need to "relieve" an are with a die grinder where the web would hit...
btw...if you know anyone who nedds one of these...I have a brand new roller ring listed in the parts forum
