kysledneck
yamaholic22
That's a pretty creative sled stand
SpiderViper
Why wouldn't you want to leave it on the ground fear of frezing?
yamaholic22
yea you should run your sled on the stand for a little while first before riding it so that you can get the driveline freed up and warmed up a little bit. Hard on belts if you don't.
SpiderViper
Oh thats food to know. I figured that at the begining of the season on the firt ride but not after lunch thanks for the info you could probably use pvc piping to for a stand correct?
kysledneck
[Yea I thought that is What you do! I have read where sleds have froze solid! Also I keep it on the stand in the garage too.QUOTE=SpiderViper]Why wouldn't you want to leave it on the ground fear of frezing?[/QUOTE]
yamaholic22
yea if you dont keep it on the stand either the lugs will bend over if its not studded or the studs will put too miuch stress on the track if it is studded. Both are not good
