Hot Clutches
C-money
Michigan
I have a 97 700sx triple PSI piped, stock primary weights and rivets, Maxx black spring, secondary is a max roller with 44/32 helix silver spring 3&3. Clutches stay nice and cool on the trail but when I jump into the powder they are both smoking hot. And tends to bog down(in powder) unless I am real hard on the throttle.
What can I do to fix this?
Thanks In advance
the powder you get into is melting on your clutches and causing your belt to slip which will also make your engine bog down......for a quick fix put some tape over your screens around the pto side and this will help...
Thanks alot
I talked to a tech guy at Maxx Perf. and he told me the same thing. It makes perfect sense, I will give it a try this weekend.
