n2oiroc
how do i totally remove the transfer rods from the top? i dont really see how the carrier wheels come off. someone point out the stupid thing i am overlooking. thanks
The carriers are a snug fit on the shaft. Nothing but fiction holds them on. Use a brass drift and tap on the center of the shaft on one side...it will slide through the tube and the wheel will slide off.
n2oiroc
thanks, i thought that was it. i just wanted to check before i start hammering.
yamaholic22
It is definately a good tight fit on those. Take a little pounding to get them off. Just make SURE you don't mushroom the end of the shaft, it is softer than you would think.
n2oiroc
i will thread a bolt in at least .75" and pound on that.yamaholic22 said:It is definately a good tight fit on those. Take a little pounding to get them off. Just make SURE you don't mushroom the end of the shaft, it is softer than you would think.
yamaholic22
if you put a bolt in and pound on that make sure you go all the way down until it bottoms out so that you don't destroy the threads in the shaft
n2oiroc
just got to trying it tonight. no luck. its on there. any other tricks? ill try it tommorrow with a bigger hammer at work.
maxdlx
VIP Lifetime Member
Yeap BFH, just be sure to have the bolt down tight to the shaft or you will take the threads out. You have to be mad at it and hit it like you mean it. It will come. Maxdlx
yamaholic22
yea you really gotta take some good whacks at those things to get them off. Get pissed the off
shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
lmfao.......and who said anger and violence never solved anything.
