Exciter570
Does anyone know if a Mono Shock skid would be able to be mounted under a Vmax4 or Vmax 600? They are starting to pop up on ebay and in the local swap sheets for cheaper than M10's. Thanks
Srxspec
Your #1 performance shop!
I believe you'd have to widen out the shafts because the tunnels are wider, but as long as you kept the distance from the center of the driveshaft to the front mounting point, the center to center on the suspension mounts, and the distance down from the top of the tunnel the same as they are in the 05 RX-1 it'd work.
i have a 97xtc skid, 2002 viper skid with updated shocks, 98 srx skid, 97sx skid, 99sx skid, tell me what you want.
Exciter570
Looking for a long travel skid with a plush ride. What are you asking for your long travel skids, and what kind of condition are they in?
viper skid has 4900mls, looks very clean, this would be the one that would ride the best, 350plus shipping. the shocks are the updated style so they wouldnt have the miles the sled has on it. they would have been put on in the second or third season.
i can put the older style wheels on it for you if you want so it will look more like what came in it for style.
the sx skids will ride ok and make the sled set like it sat when new for height. a side effect of a taller sled than it was designed for is that your caster will decrease and darting will increase. the sx skids i will sell for 250 plus shipping.
it is up to you on what you will do with it.
i also have viper skis that can be modified to fit these sleds spindle 125 for them with blue or black tips
