83 SRV 540 not firing on both cyclinders, please help.
cookie
southern NH
My 1983 SVR540 does not seem to be firing on both cylinders consistantly. Compression is even on both cyclinders and carb has been cleaned. I have spark on both, but seems a bit weaker on one. I was thinking about changing the coil. Can anyone give me any other ideas or tell me how I can verify the coil is good or bad. Thanks,
SRV540
is one spark plug wet and the other dry.Do a resistence check on the coil and wires.You might have to get them from the dealer.If they test good I think you might have a crank seal gone.Maybe that spark plug is bad
Yes one is wet and the other is dry. I have put new plugs in. I will do a resistance check on the coil. How would a bad crank seal cause this problem?
