yamvip
I'm curious on how often the springs should be replaced??Mine have about 3000 miles on them.And at the end of the season I noticed it was starting to overrev,And I'm thinking that is because spring is getting weaker? Thanks guys
pro116
Lifetime VIP Member
If the spring was getting weaker your rpm's would be down.You probaly have a worn beldt.
yamaholic22
springs should be changed around every 3000 miles, but a wearing spring will not raise your revs, it will drop them. Narrow belt is much more likely, or worn bushings, dirty sheaves, etc.
yamvip
Oh.....Didn't even think of that,reverse affect and all.Thanks guys
