Maybe I'm being real naive but I see a few wiring connections, remove belt and exhaust and then motor mounts and she pops out? Is there something special for re-installation as well? Thanks!
98srx6
Just make sure your clutches are aligned when you reinstall your engine. Have fun, its not a very bad job.
Is there a special tool required for clutch aligning?
Junior
yes you will need a clutch alignment tool, there's also an impulse line for your fuel pump coming from the crankcase and a control cable for your oil pump. electrical connections are a walk in the park.
it's not a bad job, but there's more to it than meets the eye.
yamaholic22
easy, half hour job once you have done it. Sometimes the bottom coolant line is a bia, and as junior said the pulse line takes a little gymnastics to reach without stretching it too far. Otherwise a walk in the park.
