jimmie d
What is easiest way of removing for painting the grill on the tip of the hood bottom that rotates. Is it a c clip holding it on?
Jim
Jim
redsnake3
when you unclip the c clip it holds the hood so be ready.
i buckled up my vent doing the same thing. probably best if you had someone hold on the hood when you do it.
i buckled up my vent doing the same thing. probably best if you had someone hold on the hood when you do it.jimmie d
No the screen seems to ride an an axle alone that seems to have a c clip on the end, no need to inpact the hood from what I see.
jim
jim
That pin is the hinge pin for the hood as well. If you do it just right you can pinch your fingers real good taking the hood off.
I remove the hoods on all my sleds every year for the summer. I take the bolts that hold the hinge to the front hoop off. Then that part can be taken off real easy without bending anything.
