APEXMAN
Hi guys just wondering if i should replace my fuel pump on my 00 srx or rebuild it or do they never wear out ....... just wanting to do some pm work any feed back would be appreciated thxs
SRXSRULE
- May 2, 2003
They almost never fail. I would spend your time on the power valves, clean and check the valves to make sure the cable ends are not about ready to pull through. Also check the cables for any fraid wires. Then go through your clutches, clean and check for wear. Then pull out the rear skid and check all the berarings and bushing for wear or play. New driveshaft and jackshaft bearings woudl also be a good idea if they have never been replaced. The valves, bearings, bushings and broken w arms are by far the most common failures on these sleds. ===SRXSRULE===
