handwarmer/thumb warmer?
merle ebersole
can a 2000 sxr700 be rewired with the newer two adjustment controls found on the viper. if so can you tell me how to wire it up
In my opinion no. The 2000 does not have the 300 watt electrical system. The dials do not control the warmers (directly). The warmers are connected directly to the ECU on the sled. The dials (variable resistors) are attached to another two inputs to the ECU. Turning the dial tells the ECU to send more/less power to the warmers. Your ECU does not have these inputs. Doug
