whats the biggest track that can be fit to an 03' viper.as in lug height?
redsnake3
labrador home of snow
i have an 03 currently with a ripsaw i put in myself. to clear that i had to trim the lugs about a 1/8th" because of the guards on the front cooler. if i cut them off what would be the largest track i could fit without changing to a 8 tooth driver. any help is greatly appreciated. badly need more traction for my piped viper. Please help me beat those f7's and mxz's.
:rocks:
with tunnel and heat exchanger protection removed you can go to a 1.5" real easy. ===SRXSRULE===
1.75 with the protectors removed with 9 tooth drivers (thats at the max) very tight to install though i did a 136 1.5 inch
i ran a 1 3/4 lug in a o2 viper with protectors removed and no tention on the track last year with no rubbing ....
sorry , sold the stock 9 th drivers and am using the anti ratchet 9th , i have some 8th but thats it ...
So I really can stuff a 1.5'' track in my '02 viper? It also has a Bender reaction suspension in it. No tunnel protectors or heat exchanger protectors.
Thanks Tim
