*99sRx700*
what is the best gearing for a 99 srx 700. It is completelly stock right now, but I am getting a 1 inch camoplast track, and also doing a maxximum clutch kit. I was wondering if I should replace the gears to get a better advantage, or just leave them as is?
what do you want? top end? or something that will do 100 MPH that will get there right now!!
*99sRx700*
a little bit of both, i mean 105 would be plenty of top speed for me dont yah think? Where on a lake will you get that much speed, and woudl it happen in a race?
yamaholic22
105 on speedo or radar? Stock gearing should pull you around 120 on speedo in good conditions (obviously less on radar)
*99sRx700*
on speedo. I was thinking of going like a 21/37 setup, but dont know if I would even feel the difference. And with that setup I can easily hit 105
yamaholic22
21/37 should give you quite a bit more bottom end grunt, going down two teeth on top. Yes you should still easily be able to push over 100 on top end with that as well.
