deekersrx700
Whats the best track for snowdrags? How much top end will you lose with the full block?
n2oiroc
the full blocks dont work as good as the newer tracks with an open center. try a 1.25" ripsaw or a 1.5" camoplast hillcross track. a 1" track is no good at snow drags. just ask all my friends that have a 1" what happens when i race them with my 1.25" ripsaw! if you are stuck on a 1" then go with a 9830.
deekersrx700
thanks, does the 1.25 inch ripsaw fit ok?
n2oiroc
it fits fine unless you stud it. if you want to run it studded, you need to run 8 tooth drivers and change your gearing.
deekersrx700
thanks for the info
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
You also have to remove the heat exchanger, protector. The Rip Saw track will hit them.
Bruce
Bruce
RmRider01
If your using it for snow drags I would go hillcross track or 1 1/4 six pitch it's better than the ripsaw in loose conditions.
auji700triple
yeah, well we usually Race 660 Packed!, i got a 144 and im runnin a 1.5" it shouldn't really slow me down with the power i got going on... well hopefully not..lol
