Best way to drain coolent
Well When I did it the hose had a splice in it already so I had a wet vac loosened the clamps sucked out the coolant! then I bought garden hose repair ends hooked my garden hose to it hooked another hose ran it over the hill & turned on the water! CLEANED that sucker out!! then I hooked up the wet vac and refilled with distilled water & coolant!
Take a wet dry vac and put it in the radiator cap hole then remove the rear bleeder. It will drin it almost to nothing. Maxdlx ps anti freeze is hard on vacs, so use a buddies LOL
