maxwell
What year SRX exhangers will work, and what modifications are needed?
yamaholic22
any year will work they are the same part number for all years. No mods are needed, just take out the crossover tube that is in there now and put the heat exchanger in. The hardest part is paying the bill for those things.
maxwell
Wowser, $184 from yamaha, The ones that bender sells are much cheaper.
I have one in real good shape that comes with the Bender protectors still attached, Asking $90 for it.maxwell said:Wowser, $184 from yamaha, The ones that bender sells are much cheaper.
ridesrx
oem Yamaha exchanger
Yamaha still has the one they sold to update the Viper for 60 bucks right from the dealer. Try this part number...8EK-RHECR-KT-00
Depending on what you need, the SRX exchanger has a much higher capacity than the Yamaha replacement Viper version.
If you are simply looking for additional cooling on a stock Viper the smaller one will work fine and save you a couple of bucks.
