Dave_Vmax600
i have a vmax 600 twin with carbontech reeds, aaen single, and i was going to buy the thin head gasket....i haven't jetted yet...what is the best clutch/jetting set up for this sled?
*99sRx700*
PM Turk, he knows his stuff, he will gladly help you out
Dave_Vmax600
ok thanks
8CA weights and a 51/43 helix
Dave_Vmax600
what about the secondary?
51/43 helix for secondary. play with the spring to get it to shift out to to your riding conditions you can pick up a stiffer spring for your primary to bump the engagement
Dave_Vmax600
ok thanks
yamaholic22
go with 8AB's instead of the 8CA. They are the same profile but the CA's are heavier and a little harder to fine tune than the AB's, especially on a less forgiving 600, and worse yet a twin.
some 500 and 600 twins came with 8AB.. check and see what you have
sleds that came with 8AB (1996) 500 and 600 vmax
OZ
yes but...
AB's have my vote, ...you guys should really check out the tech section on clutching, ...there's a buffet of clutch settings for most riding styles!
Dave_Vmax600
the weights on the 94 600 (mine) is 8ay
yes i owned a 94 v-max 500. sold it 3 years ago clutching is very tame. i would pick up some 8AB weights then
Dave_Vmax600
anyone dones this same setup before? before and after? need input
