viper skis
RedlineViper
Frankfort NY
well i put this in the general forum and didn't get any usefull information. i have a pretty new pair of ski doo skis that i want to put on the viper (cause i need new ones and i like these). who makes a retrofit kit to match them up? anyone else do this yet? thanks
You dont need a kit at all. I ran ski-doo dual carbide skis a few years. All you do is knock the steel bushings out of the ski-doo ski mounts and install them opposite of the way removed them. basicly there is a shoulders on the bushing, I dont recall if its on the inside or outside on the doo, but just install it the other way. Then, use your stock ski bolt, and the stock ski rubber and as your putting the bolt in, you need to add one more standard 3/8 washer on each side of the spindle to remove extar play. Its takes a couple hands, or a few trys to get them out but it does work. ===SRXSRULE===
