auji700triple
Is this clutch kit Worth buying ?? i heard the Ups and its downs.. can it Help you gettin out of the hole Quicker?? and wat type of Angle Should i go with a Bender Triple piped,heelclicker primary, Reeds/spacers and Ported with Srx heads... all i am aiming is for killing people Out of the hole and Down the line! i want them not to gain a single bit.. Espically you Joe hahahaha
You will get more efficient upshift & backshifting. You have a steel helix running on a steel roller & bearing.....virtually no friction there. Add about 10 degrees to each angle to come up with something that is close to a normal aftermarket helix. The angle you need soley depends on what kind of riding you will be doing. The nice thing about that roller is you can use a very stiff secondary spring with a lot of wrap & it will still shift out fully will still slowing the upshift speed.
redsnake3
i cant gain on you if im in front of you.
i think im gonna get the same secondary for mine.
i think im gonna get the same secondary for mine.auji700triple
hahahhaah nice one joe
