Motor Swap
prox
Mn
Will a 540 fan out of a 84 SRV bolt into a 95 Phazer? The phazer has a 485 in it now but its cooked. Thanks.
I don't want to spend alot of time or money on this. It is a matter of a good motor in a junk sled and a good sled with a junk motor. I haven't bought the phazer yet. I'll probably skip it. Thanks anyway!
It will fit. However there are some differences that might require some attention.
I don't know if it's a direct bolt in though. The 540 motor is basically the same as the ss440 motor from about 80-85. Just a bigger bore. They are single carb and the phazers are dual so that would be the biggest headache.
