Re: the $25 Shock Mounts on Ebay
Anybody tried these things? Are they legit? Will they mess up the front geometry?
Thanks in advance!
Thanks in advance!
Link?
nailsandrails
yam0498
used them on mine they raised it about 1-2 inches. just a cheap way to raise the front of your sled. it sets just about as high as my wifes 04 venom.
chance3131
your radius rods will hit when the front suspension is fully extended, like when jumping. max performance sells the whole kit to raise the front end, and I really liked it when I long traveled my srx. I bought mine used on here though, so if you are interested put out a thread to see if anyone has one.
914rippy
I WANT TO LONG TRAVEL MY SRX AND I THOUGHT THOSE E-BAY BRACKETS WOULD WORK BUT NOW I'M CONCERNED. TO LONG TRAVEL THE FRONT, WOULD VIPER RADIUS RODS WORK? AND/OR WHAT ELSE IS NEEDED. THANKS
chance3131
You will need the brackets, longer radius rods(not sure if viper rods are the right length), shock extensions, and I believe they are called sway bar spacers. It will raise your front end about 1 inch. Call max perf to see if the viper rods are the same or not. If you already have the stuff for long traveling the rear, it is well worth it to buy the front end kit. Hope this helps. I think that is what you need, atleast from memory that is all.
914rippy
Thanks to all who responed to my request .rippy
ReaperSRX
I hope the viper rods and steering rods are the right ones, i am putting viper shocks on my SRX and going with viper rods to widen to 42" to compensate for the longer shocks...... and i just got the sway bar extensions from MaxPerf...........James
