1997 700SX swapping to a Viper seat
Depends on which way you're going... The connectors are different and if you're putting the Viper seat on the SX it doesn't have the flap in front to cover the studs in the tank. If going the other way, SX to Viper, you might need 4 snaps to hold that same flap down to the tunnel... or you could just leave them off. Either way, they should bolt right up.
It boldt's right up.Iv'e done it but it looks alot better if you put the viper hose cover on the back with a viper bumper.You have to do a liuttle modifying to get the bumper on but it's easy.
i would think that would look stupid up by the tank if you put a viper seat on an sx because it doesn't have the flap to cover the anchor studs on the tank.
The fuel tanks I believer are the same.The viper seat actually looks better.srxsrules might have some pice of one on a srx.
