shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
I need a new track for this winter. Right now I have a 1" with 192 studs. I really like the studs for ice and trails, but I ride ditches mostly and some powder also. I'm looking for a 1.5"(or so) track. I found these on E-bay.
http://cgi.ebay.com/ebaymotors/NEW-...mdZViewItemQQcategoryZ100466QQitemZ4568839283
http://cgi.ebay.com/ebaymotors/NEW-...yZ100466QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
What do you guys think of these tracks??? Feel free to reply if you know of anything better.
Can I use a 1.5" track on a stock SRX with tunnel protectors???......or will I need 8 tooth drivers?
shortstop20
- Mar 6, 2005
I do ride trails and lakes sometimes also, so I want a track that is durable so that I don't have paddles breaking off every other day.
n2oiroc
the first one is a oem cat track and its supposed to be a great performer and durable too.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
NO....You will need an 8 tooth. If you need a track price give me a P.M.
Bruce
Bruce
n2oiroc
i have drivers if you need them.
shortstop20
- Mar 6, 2005
Can I use 9 tooth drivers with a 1.5" track(every 3rd clipped) if I remove the tunnel protectors???? The tunnel protectors are just welded onto the tunnel aren't they?? Do I just grind off the welds???
n2oiroc
i think you can use 9 tooth if you remove the heat exchanger and tunnel protectors. with 8 tooth just the tunnel protectors need to be removed.
no there pop riveted on the srx's
Mtnviper
Yes you can use 9 tooth's with a 1.5", after the front exchanger and tunnel protector's are removed. Actually you can go all the way up to 1.75" with 9 tooths. However it would to tall for your intended usage.
The Camo 3rd clipped 1.5" is a good track, nice and light. I've used both 121" and 136" version's with good results.
cacsrx1
Id keep using the track U have, or sell it to me.
shortstop20
- Mar 6, 2005
My sled trenches whenever I ride in the powder though....but on the trails and ice it sure is nice to be able to hook up instantly when I punch the gas.
How do you like your 1.5" track cacsrx?? Does it float pretty well in the powder?? Maybe I'm just expecting too much out of a 121" SRX.
I'll let you have 1st dibs on the track when I am ready to sell it.
cacsrx1
No matter what track U get it a 121 is only going to do so much in powder. Mine will trench like a chainsaw with enough throttle.
n2oiroc
i hear you on that! a ripsaw on a 121" viper likes to dig holes, bring your shovel!cacsrx1 said:No matter what track U get it a 121 is only going to do so much in powder. Mine will trench like a chainsaw with enough throttle.![]()
