yamiman
i bought a viper with the rear skid relocated, it had some generic rail extensions with a 141" track. i just bought 136 tracks usa extensions and a 136 ripsaw track and now it wont fit. did i need to buy a 144" track to make it work? any help would be great. thank
You will need to move the skid back to the original mount's in the tunnel, if you want to use the 136".
Or if the 136" hasn't been installed yet, Bruce would most likely let you return it, if you buy a 144" from him. You most likely have to pay shipping though.
If you go with the 144" the skid should be moved back another 1.5" from the 141" position.
skidooboy
they most likely wernt generic rail exts. you just didnt take into consideration that the relocation of the skid makes for a dramatic length change. thats why he has a 141" track on it. like said above, you'll need to put the skid back in the original mount holes with the new tracks usa extensions to make your current set up work. if you buy a 144 track it still wont work due to the length of the extension and the relocation. tracks usa extensions do not take into consideration relocation of skid. how much longer is the 136 ext v.s the current relocated 141 exts? you might be able to "cheat by getting an offset axle, larger rear idlers and swinging a 141 or 144 in with what you have but there are no guarantees. need more dimensions to help. ski
yamiman
last night i moved all the brackets back to stock mounted it up and it actually looks good. im glad it didnt work cause i think ill like the ride better like this. thanks
