shortstop20
- Mar 6, 2005
- Stickney, South Dakota
- www.snowmobilefanatics.net
The handlebars on my Exciter are broke just below the "T" section of the handlebars. Is this part a to replace or not?? I would like to get it fixed so I can ride it every once and a while for fun or sell it.
Here's a pic(the arrow shows where it is broke).
The_BeaverBanker
you might be abble to weld it. i seen it done before
Mysledblows
I've had to weld every phazer that I've owned. Mine usually break at the weld where the bars connect to the post.
mars_man
Mine broke there too. I used solid drift pin to make a handle bar riser, added about 1 3/4 " to it and welded it all in. I also made gussets where the handle bar join into the shaft.
MUCH better. But, now I can't run all that plastic trim anymore, not that I wanted to anyways.
I say just weld it up, and you'll be good to go.
