MountainMax
RE: Front Trailing Arm Swap out Questions
hey guys, I recently put a wider 42" XTC shocks, radius rods, and tie rods, and a sway bar on my 2002 mmax which was 38" wide, do i need to change my trailing arms? what is the difference in angles and what angles are changed/off, I have the camber and toe-out adjusted fine....???
The shock mount angle on the trailing arm is the only difference:
XTC: 25,5deg caster, 10deg shock mount angle. (code R)
MM: 25,5deg caster, 7deg shock mount angle. (code S)
Should be no problems using your MM arms, the shock eyelet bushing should be able to hand any binding.
