RE: I need information on setting up a front of a Yamaha XTC
MountainMax
Churchill Falls,NL, Canada
I need the specs for setting up the length and toe and camber specs for an XTC with the 42" front end, I have the manual that lists 38"
& 40" widths but I need the 42, not sure what else has this, but the XTC i s what I bought the parts off, thanks in advance, rob.
Thanks, pm me when you post the info. I am looking for the total length specs and setup for toe and camber, I have it all in my mmax book but it is not correct for my new 42" wide setup and I want to set it up proper.
toe out 0~3 mm
upper and lower rod set angle LH 93 deg
upper rod set length LH 475.5mm
lower rod set length LH 472.6mm
upper and lower rod set angle RH 87 deg
upper rod set length RH 475.5
lower rod set length RH 472.6mm
steering rods set length are at 517.2mm
any thing else...caster is set at 25.5 deg
