L84Work
When I got my viper back from Wohlfeils Yamaha it started backfiring. Since then, I put Speedwerx triples on and changed to 162.5 mains. I still have the backfiring. Additionally, T.O.R.S. kicked in. Anyone know somebody in Mid-Michigan that can fix this and/ or some advice?
I may be going through there late next week, if nobody can help out before then.
vmaxjohn
What plugs to you have in there? make sure they're solid tops, not threaded. I've seen a lean condition cause backfiring...what have you changed, and what stayed the same? Gotta ask, why put pipes on it if you've got an engine problem?! It tends to make things more complicated. Also, call Wolfiels back and tack to service...if the problem started after they worked on it, they need to make it right.
New work on anything with an engine is always suspect when a problem arises. Good luck!
Brad
- May 23, 2003
if your tors kicked in is your throttle cable adjusted right
vmaxjohn
Ya, if they cleaned the carbs, it's very easy to get the linkage out of adjustment, causing the tors to kick in, just add a little more free play.
L84Work
Thank you for the advice on the TORS. I'll re-adjust the cable.. I took down the carbs to put new mains in them and re-adjusted the cable... I probably did that. now for the backfiring problem...
I took it to Wolfeils 4 times and had the Yamaha rep try to do something for me. Each time they claimed something new was wrong.. bad gas / dirty jets ect / faulty wiring / dirty windshield .. whatever. They decided they no longer wanted to help me. (consequentally they screwed up my v-max too.) I am using BR9ES(R) plugs. Do we recommend something else?
The pipes were added due to a friend who has a firecat F7 and since I cannot be out done, I had to increase hp.
When my Viper backfired it was because i had bad plugs. Changed from BR9ES to BR9EYA, and it never backfired again.
Yammi Nut
SLED OGRE Card Brothers in Chesaning Mi. Have a very good Yamaha Mechanic his name is Mike. He has always fixed my problems. Yammi Nut
yamaholic22
Chesaning MI...Do you know Doug Gasser?
L84Work
Yammi Nut said:SLED OGRE Card Brothers in Chesaning Mi. Have a very good Yamaha Mechanic his name is Mike. He has always fixed my problems. Yammi Nut
Thank you, I will contact him as soon as the weather cools down. I did re-adjust my throttle cable and it solved the TORS problem. So far I haven't had backfiring since the last time I started it.
L84Work
Heimdall said:When my Viper backfired it was because i had bad plugs. Changed from BR9ES to BR9EYA, and it never backfired again.
I'll look into that. Has it fouled any out?
Sled Ogre said:I'll look into that. Has it fouled any out?
Sorry for my bad english! But what is "Has it fouled any out?" mean?
L84Work
Heimdall said:Sorry for my bad english! But what is "Has it fouled any out?" mean?
Have you had to change the BR9EYA plugs because they were fouled out?
Sled Ogre said:Have you had to change the BR9EYA plugs because they were fouled out?
No. I have not changed any plugs after i switched to EYA.
