Screw or Rivet in the weights in the clutch?
viper7mi
Michigan
I have a stock 03 Viper and I plan on adding a 53/43 helix with 4 gram in both holes in each weight. What did you use the screw type by Bender or a rivet? I want it to be easy to change. Thanks in advance.
i see you are looking to by a set,i took the t nuts and pins out of a hammer time set that i did not use and installed them in my original dn weights.had to drill the holes out to make them fit,it wont work on all profiles as they are wider than hc or ht but work great for dns.
