yamvip
I know I can already beat my friends vector,but what else can i do too really beat him bad????? Thanks
yamvip
no, no not triple pipes.I want the sled reliable. Plus that is very noticable.Kinda like it too be hidden.
BLUE LIGHTNING
throw a clutch kit in , makes a big difference !
yamvip
i have a clutch kit,and transfer rods,ripsaw.Maybe thinking of shaving the head,10thos.
vmaxjohn
Prepackaged clutch kits are so passe! Learn to fine tune that mama, get those rpms perfect, and hold on! Check out the tech pages for some schoolin.
Vectors run pretty strong dude...did you race head to head?
redsnake3
try porting. it wont be noticable until you pin the throttle.
also gearing and dial in the susp. that will make a big difference also.
work with the basics
porting a viper with single pipe is pointless. If you want the sled faster and dont want pipes then you need to work on clutching,clutching,clutching, thats assuming you have good traction like a 1.25" ripsaw track or studded 1 inch track to begin with. Get a good selection of clutch componets and spend alot of time along with good notes and you will be very surprised at what a little hard work will achieve.
yamvip
Yes, it was head too head,he got me out of the hole.For about 15feet then even til about 60 then i just keep pulling and pulling away from him.My clutch kit is a hauck,i believe #3.Any suggestion's on the clutching??
98srx6
yamvip said:Any suggestion's on the clutching??
Yeah, take your hauck kit out and start over.
http://www.totallyamaha.com/snowmobiles/aaTECH/TechIndex/sledTechIndex.html
tripple_tripple01
not so sure on how much he knows about clutching the viper, but try turk, that guy is a wizzard on clutching the srx's. really really help my sled!!!!!!!!!!!!!!!!!!!!
