SRX01
yamyrider
Boost Bottle Kits increase the bottom end of your power band by 8-10 HP at steady throttle by bringing up torque and horsepower sooner in the RPM range, it was not designed to add to peak horsepower but shows 3 to 4 hp on the dyno.
You can find this in the tech page.
It installes on carb intake boots.
SRX01
HOW EXACTLY DOES IT DO THAT, IF IT GOES ON THE CARB INTAKE BOOTS, DOES IT ATTACH BEFORE THE INLET OR AFTER THE OUTLET? DOES IT USE THE COMPRESSION STROKE TO SLIGHTLY PRESSURIZE IT THEN IT PROVIDES AN EXTRA AIR BOOST WHEN ON THE INTAKE STROKE?
jwiedmayer
Boost bottle
Here is a picture of the boost bottle on my sx. The boost bottle equalizes the pressure in the intake tracks. The air entering the carbuerator has momentum, when the reed valve closes the air has to stop moving or compress, with the boost bottle it is redirected to a intake port that is drawing air. Jason
Harvey
is this a worthwhile addition to an 2002 SRX?-Thanks-Harvey
